Wiring question
SoSo09
With disregard to the amount of wattage that I will be putting to my subs, I have a question about wiring.
I have a 2-channel amp, and two 4-ohm SVC subs. Currently, they are hooked up in stereo, giving them each 187 @ 4-ohm. I understand the basics of ohm loads and bridging, but I'm still a little confused on one part. I'm wondering if I can safely (or unsafely) hook up these subs to get a 2-ohm load with more wattage.
My amp is rated at:
187x2 @ 4-ohm
375x2 @ 2-ohm
750x1 @ 4-ohm bridged
From what I understand, I can't safely bridge the amp to these two subs because it is not 1-ohm stable, or even 2-ohm for that matter. However, is there a way to get the amp to see a 2-ohm load without bridging it?
Any help is appreciated! :]
wire the subs parallel. then the amp can see nothing but a 2 ohm load.
the ohm reading is the subs, not the amp.
the amp isn't 2 ohm stable bridged?
edit: no, that amp will not do what you want it to do.
SoSo09
SoSo09
Montgomery, AL
Ineed$
