wiring question
Originally posted by choochooSS wont setting the pionner to high pass block out lower hz and not pass them through at all?cause it would just block the lower signal and be done with it, sense thats what a crossover does. i was understanding that by using a crossover it will block the un wanted frequencies before they were amplified, that way u arnt amplifing un wanted frequencies.
i might be wrong because im not sure if the lower hz are passed through some other way anyway although it would be switch to high pass.
but even if i am wrong i would still use both pre amp outputs(like i said me and craig may differ)
Don't hold me to this but I believe on pioneer amps the rca output (not input of course) is a pass thru and pass thru only. I'm not positive but I am about 97% sure. So if I'm right the crossover on the pioneer amp will not filter out the low frequencies.
Can someone else elaborate on this??
-peace
bumpin_8605
bumpin_8605
knoxville illinois
MTXTANT
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
