Wiring problems. (Remote wire, possibly power)
valestrom
I have a Sony Xplod deck in my car, and my brother recently gave me his 1000w Sony Xplod Amp, and his 10" Clairon subwoofer. I spent all day yesterday wiring it into my 1990 probe. After all of it I found out something with my remote cable to my amp is messed up. Here's what happens.
With Remote Cable connected to deck and amp:
- Deck will stay on intro screen
- Can't choose a source
- Can't adjust volume
- Can't truly start the deck
With Remote Cable disconnected from deck:
- Everything works fine.
This has me really stumped, I have the wire running straight back to my amp and connected, the only thing I could think is somehow I connected it wrong, but nonetheless, it's something wrong with the remote cable and I don't quite understand what to do with it.
Here's some pics/descriptions
The Deck: Sony Xplod Cdx GT-300
The Amp: Sony Xplod XM-3001SXD 1000w
Connection to deck:
Uses a banana clip exactly like the one in the picture to the "remote" hole on the deck. I think this is the right connector to use, please correct me if I'm wrong.
Connection to amp: Simple twisted wire into the remote hole, used the button to lock in the cord.
If anyone can explain how to fix the situation where while the remote is plugged in I can't control the deck, and the amp isn't even on would be great.
um the remote turn on is a blue wire on the harness, not a plug/hole! I think your cramming a wire into a wired remote to control the stereo!
NO stop jambing things into that hole, the wire you want is on the harness that plugs into the deck it's solid blue the blue w/white is the power antenna hook the wire from your amp to the blue wire thats with your speaker/power wires on the HU.
the Hu is freezing because your shorting it out jambing a solid connecter in the hole, that is for a wired remote control for the radio it has nothing to do with the amp.
Guess it didn't take my reply, thanks a ton man. I was basing my work off of what I think it should be, but I did pull out more wires to reveal the blue/white one that said amp on it -.- Thanks a ton.
Based off GM pickups of the same year (and that was GM), It SHOULD just be for the vehicle sounds that play through your stereo, such as the door...
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
337
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
699
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
731
738
valestrom
valestrom
Calgary, AB
valestrom
Dan Medina
    Jun 17, 2024
    Jun 15, 2024
