Wiring problem
superfly17
8
TN
im gettin a single PLT15wd db drive..and im wanting to put 2 ps14000d power acoustik amps to it ..but im not sure how to wire both amps to one sub..im not even sure if its possible..a wiring diagram would be helpful..thx...Tyler
You could run 1 coil per amp and run each amp at 2 ohm's depending on what coil configuration you have and match the setting's and gain. Those amps also have a bridging synchronization just read the manuals and it will explain how to do it.
yea it came with a cable like the bass remote cable to link two amps together but i just wasnt sure it u could put both to one sub
superfly17
superfly17
TN
superfly17
