Wiring Polk 5ch amp to speakers/sub, need help!
I am in a bit of a dilemma here, I hope I did not buy the wrong amp for my setup.
I am currently doing an installation on my boat, and have the following equipment:
1) Polk PA1100.5 5ch amp
Specs are:
Amplifier Class D
Number of Channels 5
RMS Power @ 4 ohms (Channels 1-4) 80 watts x 4 channels
RMS Power @ 4 ohms (Channel 5) 280 watts x 1 channel
RMS Power @ 2 ohms (Channels 1-4) 125 watts x 4 channels
RMS Power @ 2 ohms (Channel 5) 400 watts x 1 channel
RMS Power @ 1 ohms (Channel 5) 600 watts x 1 channel
Bridged RMS Power @ 4 ohms (Channels 1-4) 250 watts x 2 channels
Total RMS Power Output 1100 watts
Peak Power Output (Channels 1-4) 200 watts x 4 channels
Peak Power Output (Channel 5) 1200 watts x 1 channel
2) 4 x Polk MM651UM Speakers
Specs:
Peak Power Handling 200 watts
RMS Power Handling 100 watts
Impedance 4ohm
3) 1 x Kicker 10" L7 Sub, wired for 1ohm load, so 600w RMS
My goal:
I would like to power each of these speakers with 125w RMS, and this amp has 4 channels. I want to power the sub with 600w RMS with the 1ohm load.
The speakers are 4ohm right now, but from what I can tell this amp will only do 125w x 4 if they are in 2 ohm? How would I wire 4 speakers to present a 2 ohm load to all 4 channels?
I also see this amp runs 250w x 2 in bridged mode, but at 4 ohms. I don't think I can run these speakers in bridged mode / 2 channels right? Since they are 4ohm speakers, I dont think I can wire them to present a 4ohm load when bridged?
I am confused as to how I should wire these speakers optimally w/ this amp.
Any help would be appreciated.
Thanks
Kris
when you bridge two chanels on a 4 chanel amp you will loose seperation everything coming from that chanel will be mono. so your right you have the wrong parts to get what you want either change speakers or amp. I also think you would be fine with what you have
meatpunch
meatpunch
Orange County, CA
sexy
