anj46907
No Longer Truckin
got two 18'' FI BL's, dual 1's, cooling, daily option and flatwind ... got a good deal on a powerbass xa 4000d amp. my question is. these being 1 ohm subs what ohm load should i wire these up to with amp. right now there wired up to two ohms on two kicker zx 1000.1 amps (one per sub)
amps specs as follows
SPECIFICATIONS:
• 4 ohm Power : 1350W x 1
• 2 ohm Power : 2700W x 1
• 1 ohm Mono Power : 4000W x 1
• Strapped Power : 8000W
• Total Harmonic Distortion :
• Frequency Response : 18Hz - 250Hz
• S/N Ratio : >90 dB/W/M
• Damping Factor : >200
• Input Sensitivity : 0.3 - 8.0 volts
• Crossover Slope : 12 dB
• High-Pass Crossover Freq : 50Hz - 250Hz
• Variable Subwoofer EQ : 0/+18 dB
• Subwoofer EQ Frequency : 45Hz
SPECIFICATIONS:
