Wiring of dvc subs and 2 channel amp
Wire each sub parellel, Each sub will only have 2 wires coming from it.
Just because is has 2 voice coils doesn't mean you'll have to have 4 wires coming from it.
______VoiceCoil 1 VoiceCoil 2
You Have:Black*____red
_________red*______Black
So wire: Black* to Black and red* to red, then have 2 wires
leaving the red and black. that will give you 2ohms.
P.S. don't pay any attention to the ____ marks.
snapnakk--is your 2 channel amp
1 ohm bridge/mono stable
then wire each sub into 2 ohms
then wire both subs together (parallel)
for a 1 ohm load to your amp.
if not
is it just 4 ohm bridge/mono stable
then wire each sub in stereo (2 ohms)
one sub for the left channel
one sub for the right channel
wiring both sub in stereo each
sub will have the the most power
that your amp can put out at a 2 ohm load
the amp is 2 ohm stereo stable. So how would i put the wires to get that 2 ohm load. I dont know exactly how to hook them up. I do want the most power possible from the amp without wreckin anything.
thanks so all the help.
later
for each channel of the amp: wire the amp pos(+) to the pos(+) of sub of both VC. and then the amp neg(-) to neg(-) of both VC. repeat for the other channel of the amp. this creates a 2ohm load for each of the amps channels.
see below:
Snapnakk
Snapnakk
MN
Snapnakk
ThxOne
    Aug 15, 2026
TechGuru88
    Aug 10, 2026
