wiring my dual voice coil sub
audiotroubles
I have my 4 ohm DVC sub wired with the voice coils in series from a bridged connection to my amp:
+ from amp to DVC1 + ; - from DVC1 to DVC2 + ; - from DVC2 to amp -
what did I do? is this correct? am I running at 4 ohms? it works well, but should I be wiring it a different way?
okay, so maybe I'm running at two ohms. I don't know, so I was hoping someone could tell me according to how I have explained how it is wired.
amp: Diamond Audio D3 600.1
sub: PG Xenon X10D4
I mainly just want to make sure it is wired right. It works fine, so I assume so, but I could use some confirmation on it.
The way you have it explained, it will be running as 8 ohms. To make it 2 ohms, run a wire from amp + to VC1 +, then a jumper from VC1 + to VC2 +, and a wire from amp - to VC1 -, then a jumper from VC1 - to VC2 -. Will find a diagram for you quick.
According to the specs on your amp and sub, if you run it at 2 ohm, the amp will be putting out 450 watts rms. Your subwoofer is rated at 450 watts rms. If you have it wired the way you described, that sub is only recieving about 225 watts rms.
Cool, so I should probably rewire to get the 2 ohm power out of the sub.
The reason that I wired them in series like that is that I can't fit two wires into the sub's set screw connector.
I am using 10 gauge wire and only one fits into the set screw connector.
Do I just cut about half of the strands from each wire so that both wires will fit when both are put into the set screw connector?
audiotroubles
audiotroubles
Denver, CO
audiotroubles
