wiring DVC 4 ohms in series?
ok that makes sense lol
but can i use the jumper cables instead
cuz i got em, im not sure what they for
thats what they told me
i dont have manual for the type rs so i dunno =/
you need to use speaker wire.wire that series parallel (speakers in series | VC parallel) for a 1ohm load if your amp can handle it
what you suggested 2+2=4 R= 4ohm not 1ohm
it should be parallel/parallel (speakers in parallel | VC parallel) would present a 1ohm load
1/R+1/R=1/R,
1/2+1/2=1/1 R=1
that wired to 1 0hm correct?
can i still wire it like that on a 2 channel amp and just ignore the second channel
if im using two 4ohm type r
and a audioque 1200d?
1/R+1/R=1/R,
1/2+1/2=1/1 R=1
DVC4 sub wired in parallel = 1/4*2 = .5ohm
2xDVC4 subs wired in series = .5*2 = 1ohm
that wired to 1 0hm correct?can i still wire it like that on a 2 channel amp and just ignore the second channel
That amp can handle a 1ohm load. there is only 1 channel. But, two sets of speaker posts. You should use only 1 set of posts.
so to get the best out of the aq and the 4 ohm type r's
would be this setup
Wire it this way
Edit: man I'm slow today. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
DVC4 sub wired in parallel = 1/4*2 = .5ohm2xDVC4 subs wired in series = .5*2 = 1ohm
HOW?
one question how do you get .5 ohm load out of a single 4ohm DVC sub
last i checked a single DVC 4ohm sub can only give you a load of 2ohm(coils wired in parallel) or 8ohm(coils wired in series)
dredey
dredey
houston tx
shaneb
