Wiring Config
dubsports
My friend just picked up an xtant amp to power a pair of kenwood 10's.
Will it sound better if I wire it
2 x 100 @ 2 ohm
or 1 x 200 @ 4 ohm
Its not stable bridges @ 2 ohm so theres nothing to worry about there.
Will one config sound better than the other?(since they're the same power outputs)
Originally posted by dubsports My friend just picked up an xtant amp to power a pair of kenwood 10's.
2 x 100 @ 2 ohm
or 1 x 200 @ 4 ohm
It doesn't really matter either way, as long as u can get the correct load with ur voice coil confguration. What config are each of those subs...you may only be able to wire them one of those ways. I doubt those kenwoods are svc 2ohm...most likely they are svc 4 ohm. If they are svc 4 ohm, the ur pretty much screwed. BUT, let us know...peace
NG
You will not be sending much power to each sub then. You will be sendin each channel a 4 ohm load. You were getting a 100 watts each channel at 2 ohm. So now your getting less than that. Whats the rms on the sub?
dubsports
dubsports
Calgary, AB
DaBaller504
