wiring components?
Most, if not all components come with a crossover of some type, all speakers are usually connected to this crossover (some exceptions). This means that the crossover has an input from the amp and then two sets of outputs, one for the tweeter and another for the crossover. Each set of speakers has it's own crossover, meaning the left and right speakers have their own. If this is what you have then yes, you can bridge your amplifier into two channels and connect it into the crossover.
The second option is usually found with basic components. The tweeter only has a crossover that is inline with it. The tweeter hooks to this crossover and than hooks into the mid (a parallel circuit). The mid is running full range (OK but not the best) and in turn is hooked to the amp, be it a 2 channel or 4 channel in bridged mode. Hope this helps you.
To make it simple, you can run one midrange to one channel and one midrange to the other, then connect the tweeters to those midranges with a inline capacitor capping the tweeters off as to not play any bass or midrange, Just treble.....
Most, if not all components come with a crossover of some type, all speakers are usually connected to this crossover (some exceptions). This means that the crossover has an input from the amp and then two sets of outputs, one for the tweeter and another for the crossover. Each set of speakers has it's own crossover, meaning the left and right speakers have their own. If this is what you have then yes, you can bridge your amplifier into two channels and connect it into the crossover.The second option is usually found with basic components. The tweeter only has a crossover that is inline with it. The tweeter hooks to this crossover and than hooks into the mid (a parallel circuit). The mid is running full range (OK but not the best) and in turn is hooked to the amp, be it a 2 channel or 4 channel in bridged mode. Hope this helps you.
hey im running cdt components and im looking to install my 2 channel mtx. i have everything hooked up to the xover and i was looking for advice on how to install them. i have a real basic idea of how to do it, but any help would be awesome. i already have a sub amp.
DbRufus1234
DbRufus1234
Northport, Alabama
slick rick
AJ (ACE)
    Jun 28, 2026
