Wiring Advice for subs and crossovers
Myster
I am finishing up my audio system and want to make sure I have my wiring correct.
I have a set of CDT crossovers and they have a screw/plate type terminal. When installing the speaker wire to the terminal, do I have to use a connector or just the stripped part of the wire enough?
Also, I have a pair of Elemental Designs 9kV.2 w/ dual 4ohm voicecoils; wiring them like the diagram I take one run of speaker cable connect the (+ -) and connect them both to the (+) on the amp and them run (+ -) each to a (+) post on each sub / I take one run of speaker cable connect the (+ -) and connect them both to the (-) on the amp and them run (+ -) each to a (-) post on each sub.
Am I good to start connecting?
you dont have to use a connector to connect it to the amp. i have used bare wire before, i just put a slight curve in it to slide it up behind the screw and then tighten it down. as for the wiring it appears you ahve it right
Myster
Myster
Scottsdale,AZ
MikeofTulsa
Mike Mccabe
