Wiring a RF Power HX2 at 1 OHM?need help!
  • 3
ViCk-BuMp
this is the only wiring I have and it's only a 4ohm load but I want to have a 1 Ohm load so please help!!! mine are the Dual 2OHM dvc and the wiring I have for the 4 Ohm load is connecting the wire amp+--------------sub+ amp- ---------- sub- and then a wire with + & - =4OHM,
but I want 1ohm, how do i get it?
Wire them in parallel.
Amp + to both coils +
Amp - To both coils -
This will give you a 1 ohm load. I don't recommend this unless your amp is designed to run @ 1-ohm. Most amps are only 4 or 2-ohm stable. So a 1 Ohm load would eventually destroy the amp.
Should be.
What happens with amps that aren't 1-ohm stable is too muh current passes through and burns them out.
A 1-ohm stable amp has the ability handle this current and won't burn out
last tiem i checked, teh bd1000 was NOT 1 ohm stable...
RF doesnt seem to like making amps that like 1 ohm laods....
the JBL will however be stable at teh ohm load, just make sure that it is ventilated enuf as it is known to get warm to the touch under such a load..
also, make sure it is getting enuf current..
4 awg, nuthihng less....
and it will sucka LOT of current so watch out...
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
11
Some at DIYMA and other places have tried this Oscilloscope as well and got good results shockingly for such a cheap unit...
8
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
79
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
358
ViCk-BuMp
ViCk-BuMp
San Diego CA
Wonderbread
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
