Wiring 4 RE8s to 1ohm?
620hpcrx
Im sure there are more than 2 ways to wire 4 d4 coil subs like rockfords site shows. Would parrallel/series wiring achieve a 1ohm load? And to wire this way you take the + from one vc and connect it to the - of the other vc on each sub...then you connect the remaining + to the + on the amp and the remaining - to the - on the amp? Just want to be sure before I buy them.
Each dual 4 can be wired for 2 or 8 ohms.
With 2 d4's, you can wire it 1, 4, or 16 ohms.
With 4 d4's, you can wire it for .5, 2, 8, 32 ohms.
Knowing that, you'd want an amp that'll put out it's maximum wrms at those given impedances.
620hpcrx
620hpcrx
Bellingham, WA
Vestax
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
