Wiring 3 subs NEED HELP
zyklonb
new to car audio know basically nothing
need to know if first this is possible and should i do it
i have a planet audio amp specs:
Max Power (1 ohm) : 850w x 1
RMS Power (2 ohms) : 600w x 1
RMS Power (4 ohms) : 350w x 1
Signal-to-Noise Ratio : 100dB
Frequency Response : 20Hz-250Hz
And want to purchase 2-3 ED db500's 12's
http://www.tcsounds.com/db500.htm
how would i wire 3 subs to run off of 1 amp if its possible ?
and would this be enough power or shouldi just run 2
If your not wanting to spend alot of money and dont want to purchase another amp or buying 3 dual 2 ohm subs which can get exspensive then I would go with these
http://www.mach5audio.com/index-2.html
The MAW-12 which is only 56 bucks a sub, and its a quality sub....I would buy 2 and wire them to a 1 ohm load
And turn you amp level down a bit to push about to push about 700 watts to these subs (350RMS each)
Which you should be happy //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
zyklonb
zyklonb
new york
zyklonb
