Wiring 3 subs 2 Amps
Spldecendant
Ny
I'm wiring 2 amps to 3 subs. I'm going to put 3 Postive to one 3 negative to the other same for both amps. But how will I strap the amps if this is the case. Also what amps would you feel ok with strapping at .67 so .33 each amp. It's going in a band pass so impedance rise is alittle higher then regular ported enclosure
What subs? Yes, they do make a monoblock big enough. What's your electrical?
3 nsv3 18's there in a 4th order I was looking to strap 2 ampere 7500's at .33 each. Electrical is 2 370 mechman 6 phase external reg units. 8 runs Postive is 2/0 sky high same negative with, 12 deka g31's
I'd rather give one amp 2/3 ohms than two amps 1/3 ohm. Hby?
That's why I'm asking for more info .. I'm sure he has other options wiring wise .. We don't know what Amps .. Or sub coil configuration ..
But I'd almost always choose 2 amps over 1 .. and there's lots of positive sides to that as well .. Especially on the meter etc..
Ya those amps should be able to handle that as long as voltage stays up .. I'd watch a couple vids on strapping amps tho because it's sounding like that's the issue .. Watching someone then copyin is usually the easiest
There d1's
---------- Post added at 08:18 PM ---------- Previous post was at 08:17 PM ----------
I get how to strap amps lol if it's like 4 subs 2 amps but with this 3,3,3,3 coils I'm not sure which way to do so
They still have 3" coils.. Three separate amps may be even better.
As far as monoblocks:
Audioque 20k
Banda 30kw
Taramps 30,000
also more
They still have 3" coils.. Three separate amps may be even better.As far as monoblocks:
Audioque 20k
Banda 30kw
Taramps 30,000
also more
Aq20k does only about 10k and if I wired to .67 it's going to rise to about 1.5 2 probley so if I'm lucky 6500w clamped I want at least 4-5k clamped to each woofer, and Brazilian amps arnt good to be wired under 1ohm, other wiring configuration is 1.5ohm no good either won't put out the power
Spldecendant
Spldecendant
Ny
LosIsATool
BP1Fanatic
BP1Fanatic
