Wiring 2 W6v2's to JL 1000/1
Cshread
Im trying to figure out the best way to hookup my new 12W6v2's to a 1000/1, would i go want to go 4ohms or 2? And i would want to do this in series/parallel
correct? And does anyone have suggestions as to how to tune the gain and what not?
i don't think it would matter would it?
i think jl amps give you the same power at any impedance
so wether you do em parallel or series they will still get 500w each
Technical Specification
* Sensitivity: 85.9 dB
* RMS Power Range : 400 Watts
* Peak Power Handling: 800 Watts
* Impedance: Dual 4 Ohm
* Diameter: 12 Inch
Features
* Nominal Diameter: 12 inches (300 mm)
* Continuous Power Handling: 400 Watts
* Voice Coil: 2.75" diameter, 4-layer, Kapton former
* Dual 4 ohm
* Xmax (one-way, linear): 0.65" (16.5 mm)
* Sealed Enclosure Range: 0.90-1.50 cu.ft. (25.0-42.0 liters)
* Ported Enclosure Range: 1.25-1.75 cu.ft. (35.4-49.5 liters)
* VRCT Technology
* W-ConeT Technology
* Elevated Frame Technology
* Floating Cone Attach Technology
* NeckVentT Technology
* Priced per speaker
Cshread
Cshread
Austin, TX
Adnan
