wiring 2 subs
Originally posted by Jdogg i have 2 audiobahn flame q 12's. i am getting either the jl1200.1 amp, or the BA1600 amp. how should i wire the subs??? any help would be appreciated. thanks
I suggest getting the Audiobahn A18001D amp, it will give those subs around 1000 watts each...
Audiobahn subs aren't all that efficient, they need a lot of power to get them moving...
Anyway, you want to wire those subs in parallel, like so-
Size 12 -inch
Impedance 3 ohms
Cone Material Aluminum
Surround Material Foam
Sealed Box Volume (cu ft) 0.77 - 1.27
Ported Box Volume (cu ft) 2.585
Port diameter (inches) 3
Port length (inches) 8.529
Free-Air No
Dual Voice Coil Yes
Sensitivity 96.4dB
Frequency Response 20 - 0.5k Hz
RMS Power Range (Watts) 50-1100
Peak Power Handling (Watts) 2200
Top Mount Depth (inches) 6 1/2
Bottom Mount Depth (inches) N/A
Cutout Diameter or Length (inches) 10 7/8
Vas (liters) 33
Fs (Hz) 31.5
Qts 0.35
Xmax (millimeters) 18
Jdogg
Jdogg
syracuse
Jdogg
