Wiring 2 Sub
pspkid
Hi , i have pioneer 9601 Mono Amps with two speaker terminal
4 ohms: 500 watts x 1 chan.
2 ohms: 800 watts x 1 chan.
1 ohm: 1200 watts x 1 chan.
and i have two 2 inch pioneer subs 400 watts rms each so how can i wire them to 2 ohms ?
Hi , i have pioneer 9601 Mono Amps with two speaker terminal 4 ohms: 500 watts x 1 chan.
What is the ohm load of you subs? If they are single 4 ohm, just connect them to the amp. If they are dual coil, they would have to be dual 2 ohm. Can you post a pic of your subs and amp?
Thats bad //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif , how about 1ohm load ? will it be overkill ? since my subs are 400 rms watts
pspkid
pspkid
Dubai
macsdad
