Wiring (2) RE SX 12's
937DYTBOI
TL>you
Got a question about wiring the RE SX 12's up to an Orion 2500d. Should i wire them them straight up to the amp cause it has two bays, a speaker on each sub which will have them at 2 ohms each right? Or should i wire them together to get a .5 ohm setup. Will they be ok recieving so much power at .5 ohm dont want to fry them but want it to be loud. Its going into a ported box which is about 32HZ i believe
I dont know how the amp will like .5 daily, but I wouldnt do it.
The best thing to do, is to wire each sub in paralell, then when they are both wired like that, wire the subs to series.
That will give you a 2 ohm load on the amp
937DYTBOI
TL>you
937DYTBOI
Dayton,Ohio
937DYTBOI
BP1Fanatic
BP1Fanatic
