Stel
That is something to watch out for, most cars go with the cheapest method which is a simple switch on each door. But if IC's are involved a diode should be also be placed in series between the new 12v + feed and the path back to the integrated circuit to prevent current flowing in that direction. Or use a relay, I like avoiding relays unless needed since they are mechanical devices and more likely to fail at some point, and it's a bit more wiring. Though with the currents involved, it may be easier in this case just to go with some relays.Depending on the vehicle, the door lights are activated by the computer not a direct switch. Apply 12v where it wasn't meant to be and the computer gets a bit upset. A diode could keep it from being a problem...
I think he already has a switch installed, a fog light switch and I assume he wants independent control from the dome light.Or depending on the car you could probably tap directly into the domelight switch which would allow them to turn on with the door open or whenever you turn the domelight on with the switch. But I would definitely use a relay as opposed to running 8 leds directly off a door trigger.
