Wiring 2 DVC Subs
Yes, my amp is bridgable, but how do you wire a dual 4 ohm voice coil down to 4 ohms? Or, if I can't run each channel directly to a voice coil, would it be better to just bridge the amp to 2 channels and only use 1 VC from each sub? I've never had DVC subs before, obviously, but I would like to use the Shivas with what I've got.
your best option as i see it is to wire each sub 8ohm (series)
and then bridge chs 1&2 to one sub and 3&4 to the other
i say this because i doubt your lanzar 4 ch is 2 ohm stable
Well, I guess I'll just look for a SVC I like and can afford, because I want to use all 800 watts RMS at 4 ohms. If I'm right, If I run 8 ohm subs, I'll only be getting half power. Is this correct?
setwhi
setwhi
Bremerton, Washington
setwhi
vegang
vegang
