Wiring 2 Dual Ohm Subs
colt325e
This guy at a car audio store said that i have to wire my two 15s (Dual 2 ohm) like this
because my amp is mono, but cant i just wire them separately like:
and have the subs going seperately into the amp at 1 ohm, or does it have to be at 2 ohm?
What Im saying is if I wire them independently. Like wire one sub to 1 ohm, and the other sub to 1 ohm, so then id be running 2 positve and 2 negative wires to the amp. instead of 1 positive and 1 negative.
You have a mono amp, so you have one positive and one negative output. You can't wire them independently to it. Wire them together at 2 ohm. It will be fine.
A lot of mono amps have a pair of outputs to allow for multiple speaker leads, but Colt, those terminals on your amp are actually the same connection - they're parallel to each other just inside the amp. Whether you wire both subs to one terminal or one sub per terminal the amp still sees 1/2 ohm. You're going to have to go with the 2 ohm configuration.
colt325e
colt325e
Sactown, California
colt325e
vegang
vegang
