wiring 2 amps
What I think you have disjointedly asked is if it is possible to physically combine two amplifiers and utilize their wattage together to drive a single thing? (in this case two subwoofers?)
If my assumption is true then what you are referring to is called "strapping" amplifiers. There are a few amps available that are strappable but they are the exception rather than the rule and those that are (iirc) require that you are using two identical amplifiers.
I will further assume that the amps you have are not of the strappable variety since you did not enlighten us as to what exact amps you have.
So, after all of my babbling, the easy answer to your question is simply No.
also, what type of ohm rating would i get if connected (2) 4-ohm subs together.
2 Ohms if wired in parallel like this:
Or 8 Ohms if wired in series like this:
my fault the subs are 2-ohm and i have them wired giving a 4-ohm load. now if i connected these 2 subs to a 1 channel amp, what type of load would it be?
second
I have 1 sony xplod 2-channel 1200 watt amp (1 in-rca and 1 out-rca) and a shitty 1-channel boss 1200c amp (1 in-rca). currently i have the sony amp bridged to one sub, and the boss amp to the other sub. all of this is 4-ohm wiring. And basiclly is there a better way of wiring this system?
Again, it will depend on how you connect them exactly. A pair of SVC 2 Ohm drivers wired in parallel will yield a 1 Ohm load.
A pair of SVC 2 Ohm drivers wired in series will yield a 4 Ohm load.
second
If your subs are single voice coil drivers with those coils being 2 Ohms then no, none of it is 4 Ohm wiring.
Get better amps is my first thought...
trigga_b
trigga_b
chicago
Prowler573
vegang
vegang
