wireing Saz-1500d
I got a ? to on this same subject......
if i have a one channel amp that has 2 pos/ and 2 neg, you all are saying that the speaker inputs are parralled at the amp....
well what if i have a 2 channel amp that is 1 ohm stable too.... if both subs are wired to 2 ohms and i put them in the amp seperately, is the amp seeing XXXwatts X 2 at 2 ohms...... or is the amp seeing the 2 2 ohm wired subs and dropping it down to 1 ohm??
Its seeing one ohm pure and simple. Drivers act as resistors and resistors in parallel lower the overall resistance. The Req of a parallel combination looks no different to the voltage supply than the parallel load.
Wragold
Wragold
Charlotte, NC
Jdm94Coupe
