wire to big?
  • 3
rsflores
just tryin to live,life
8,345
houston,tx
ok hers the set up lanzar 530 75+4 + 150+1
i keep blowing tweeters on comp sets. the last were a set
of jbl 6.5 comps that rms goes from 20 to 200 i called jbl to confirm
this and told them what power they would get they said no prob
i have 4+6 at 60 rms w/ no prob
the wire im runnig to the xover looks big compared to the others
that comes w/ the speakers , i've had no probs w/ the mids
just the tweeters. these are rated high (up to 200 rms)
all wires are hooked up right could they be to BIG?
i've had 6.5 coaxles (at 60 rms) hooked up and had no probs.
lost in space!!!! help please!!
Either your giving them too much power or too much distortion. Only time the size of the wire would be a problem is if it's too small, But more then likely it is just too much distortion
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
109
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
569
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
908
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
884
rsflores
rsflores
houston,tx
chris229
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
