Wire size.
cotjones
Think 4 awg cable is big enough for a 1500watt amp running 3 10's? normally i'd just run 0 for the hell of it, but space to run the wire through is an issue and right now 1 10 on 500 watts rocks my car pretty decently so i can't picture myself using all of the amps potential to push 3.
it might work
I'm thinking if anything it will heat up or blow fuses in which case i could replace the wire with a bigger gauge or add another run if it doesn't work.
I'll just have to keep a close eye on the wire at first to see how its going to react.
Has no one designed a corrosion-proof circuit breaker yet?
cotjones
cotjones
Wilmington, NC
Buck
Mike Mccabe
