Wire set up to amp and subs?
Willkas
I wired the amp to the subwoofers, the power wire is set, the ground wire is set, but the remote turn on I understand I can either wire it to the hu or to it's fuse in the fuse panel. Is this true? It has a low input RCA line on the amp, and a plug in high input on the amp. I'm only supposed to connect one, where would they go? There's also no RCA input on the hu...it's a standard car radio. And when I took the radio out all I saw was 2 sets of plug in wires. As mentioned I'm installing a sub system. Amp and subs, for the high input, I need to wire them to the rear speakers or the subs? The subs are already holding out their wires coming from the amp.
So basically my question is where does the remote turn on go, and where would the high or low inputs go.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif:confused://content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
This is atleast the 3rd time i seen these same questions from you. You only need to make one thread and reply to it, not make new ones. I have posted in one of your other thread as have a few other people and there should be enough info there to get you going and if not just post in it again, dont make another thread..
Willkas
Willkas
Los Angeles, CA
westman995
vegang
vegang
