Wire management ? opinions
jeepguylv
I am getting ready to start a build and have a lot of ideas on wire management but would like to hear some opinions maybe see some pics of your installs to get some ideas.
I would like to strap down all my wiring throughout the vehicle from batt. to amps, door speakers to amps, subs to amps, ect.
since I will be using my jeep for off road fun as well I would like to see and hear more options besides the old zip tie. there will be a lot of vibrations so I will be using a type of tech flex but as far as strapping wire to the doors, floor, ect. I need to do it in a way so it will not rub against any paneling.
so please tell me what works for you and where I can find such products.
thanks
mike
Hot glue can work well with some materials. Or just the trusty old screw down wire holders time consuming but should never fail. Also if you havent deadened the truck yet run the smaller wires then apply deadener over top of them. Just my 2 cents
I am interested in the deadner over wire idea, I may try that, and I use a screw down cable strap with rubber on the inside metal on the outside for work and I was going to use those under carpet and panels, but wanted something a little more attractive for the ones that will be exposed under the hood and in the cab. just haven't found anything I like yet, thought about the different colors of Velcro strap but that's almost like zip ties.
jeepguylv
jeepguylv
las vegas, nv
jeepguylv
