Wire adapter question....
runamuckr
Issue at hand --
Kicker amp calls for 8 gauge wire. Amp uses a set screw terminal for wires. I'd like to run 4 gauge wire to the amp so not to starve it. But 4 gauge will not fin in 8 gauge hole.
My question is: Will the stinger 4 gauge to 8 gauge adapter work for this??
Any info on these states only that its for bringing 4 gauge to 8 gauge, can't find anything on if its safe to use on amp terminals or not. Stinger says its safe for distro blocks.
AND, if I can't use this directly to the amp, will I have the same benefit if I run 4 gauge to a distro block, and run 8 gauge from the distro to the amp, keeping the 8gauge as short as possible of course.
Thank you in advance for your help.
i'm not sure what your reasoning behind this is unless you're running an extravagant length of wire from the battery. if the amp calls for 8ga i don't think there will be a problem under normal circumstances.
I don't anticipate a problem but thought I'd take the extra percaution. So there is no need to gauge up the power wire? Its a small amp 300w mono. I just figured I save having to run bigger wire in the future. I'll have to dwell on the subject for a bit.
runamuckr
runamuckr
nashville
runamuckr
