Winners only.
The whole reason people ask someone to denounce anything is to find a "gotcha" moment...
Personally if you point blank asked me if I denounce anything...You're liable to get told to fck off 🤣🤣🤣
Target? 🤔
They aren't ..real white supremist are a small fringe group...
I'm not sure where the line between a "real" white supremist and a "kinda sorta" white supremist gets drawn. Does one have to collect Nazi memorabilia and burn crosses to be counted as a "real" white supremist? Nevertheless, in elections decided by 2-3% points, I can see why the GOP is reluctant to tell the white supremist to "F' off and we don't want or need your vote." I suspect the real + "kinda sorta" white supremist add up to much more than 2-3% nationally and significantly more in certain red states and the bible belt.
I hear the Bible belt is full of racists all the time...and there might be small pockets here and there...I live in the Bible belt (moved from tacoma wa) and haven't seen it anywhere in my travels...but then again if religion is your thing and you're white...You're a white nationalist by default...
Hell if you have doubts about the govt and white...or if you don't go along with the "inclusivity" nonsense and you're white...if you're not a Democrat and you're white...if you believe in achievement based results (school or in your career) and you're white...in some circles just being white...these are reasons people have labeled "white supremacists"...
When I was in the Marines and I had to room with openly racist Marines, the were all from the bible belt other than the openly Nazi guy from NY. I'd say close to half the Okies I've meet were racist. Can't say I remember any of them reading the bible or going to Sunday Services. I suspect most White Supremist probably aren't that religious.
Are you saying "not-real" white supremist are this category of people? The category were certain leftist groups label just about any and everything as racist? On that we can agree.
I'm definitely not saying white supremacists don't exist...99% of "white supremacists" being called that ain't that...and counting on them as a voting block is about as foolish as running on an actual issue these days 😂
The biggest common theme I've seen from any racist pos I've met...is a total lack of involvement in actual politics...they're to busy preaching to each other how great they are (not just white racists but all racists I've met regardless of skin color)
Slo_Ride
Regulator
Slo_Ride
ATLANTA
Buck
vegang
vegang
