Winners only.
So you made a pizza from the instructions in the book "Pizza's For Dummies" and you figured it was decent enough to brag about so you infiltrated a pizza forum to boast and then claim yours is the best pizza made and demanded people to provide proof when they told you that it isn't. You may have also provided graphs of your pizza up against the likes of Tombstone, California Pizza Kitchen Pizza, Digiorno and so on and I am sure your pizza ranked #1 huh?
As usual, your assumptions are incorrect. Do you make them and share them just so you can show how little you know?
Let's start simple for you: 1. Making a word plural doesn't require an apostrophe. Get an education.
2. I tried many many times to make a good pizza and was never happy with the results. I got advice from a pro and it upped my game tenfold, but I'm still only 75% of the way to a pizza I would compare to a NY/NJ pizza.
Unlike you, I don't think I am automatically right all the time. I know when i am wrong and I try to correct that to be right.
Example: You STILL think your belief that there are no nerves in bone is correct, and that the entire medical community is confused about that fact.
And you will fight to the end, claiming you are correct.
BIG difference between us, kid. You revel in not knowing.
Almost always... what have I got right?
Good question. So rare I can't pick one out right now.
It was a preemptive assumption... just happened to be right.
A "preemptive assumption"? So you assumed before-before? Assuming can only happen BEFORE knowing, and "preemptive" means "before".
Sounds like the idiots who use phrases like "newly redesigned" or "LCD Display".
You work for the department of redundancy department.
And let's not gloss over that you claimed you made no assumption while also telling us you made an assumption.
Keep your lies straight. or at least don't SHOW us they are lies right after you tell them.
Right, we should just discuss information obtained through Google searches. You do know that when you do that you are just discussing someone else's knowledge. You have gained nothing from it. You are literally making yourself a middle man then bragging about what you posted. Why don't you just go directly to the source of the information and ask them for some cookies and a trophy.
Right, because you actually figure everything out yourself instead of using knowledge that already exists. Never read a book. Never relied on knowledge that existed before you.
You designed and built your own Ford Escape, and Hyundai Elantra. You designed and built your own computer and all the components therein. You designed and built your own cell phone. You were self-taught and gave yourself your own diploma in biology. You performed surgery on yourself after you trained yourself to be a surgeon.
Of course, this was all after you created fire for all of mankind, and discovered gravity.
With all you must have done in your life as such an independent thinker/explorer/discoverer, at what point did you build the country for us, write all the laws, and create the government? How did you manage to get Shakespeare to put his name on all those plays you wrote?
Was it cool when you built that spaceship and went to the moon and back?
I can only imagine how many patents you must hold for all of your creations.
And yet you can't live on your own without a caretaker. Odd how that works, eh?
Too bad you slipped up when you declared Camp Ripley biologically safe, but I guess it's bound to happen with having so much other stuff on your plate, huh?
They say even god made mistakes, so I guess we can't fault you TOO much.
Why don't you just build it... you are probably better at everything than everyone on the planet.
Why so full of angst, junior? Take a doggy downer or something.
And work on your comprehension. Your skills are sorely lacking: "Probably built better and to tighter tolerances than most humans could muster." is what I posted.
It's possessive, not plural. The owner being the dummy. Just because you choose to use the word "in" one way and I am using it literally does not mean I am wrong. I am 100% correct. I do not need your approval to know I am correct.
You made the claim, now prove it.
Wrong, If you provide no information I now have to assume AFTER. Funny how that works huh?
See above.
Why so serious? Figuring something out is not the same as engineering and building. Take a valium Rob.
See how condescending you get when you get butt-hurt?
Look at the date. Pretty sure I was right here on this forum and in the state of Ky in Oct. 2023. Not to mention I never, not once said we were there to look at the wells or water at all. There are things that go on at that facility that you will never be aware of and the effects of the surrounding areas were indeed biologically safe when tested, when we were there. It had nothing to do with water. Get your information together before you try to insult people.
HHAHAHAHA. Perfectly illustrative of what I said about you.
Instead of simply admitting that you f***d up and used an apostrophe in the wrong place, you'll create a premise that you wanted to title an instructional book "Pizza Owns For Dummies".
Inanimate objects cannot take possession, so your attempt at spin makes your title even dumber than if you had just run with "Pizza IS for Dummies" instead of that "possessive" pizza nonsense.
And you STILL argue that the entire medical field is using word "in" incorrectly, but you have it right.
IT's weird the hills you constantly choose to die on. I'm literally laughing, trying to picture a Pizza that owns a person. It could be a Veggie Tales episode. Pepper and onion pie runs for mayor.
Can't think of one, so that must mean NONE of your assumptions have ever been right.
Good job.
You can't assume AFTER you know something. Do you understand what assumption even means?
See above.
assume - suppose to be the case, without proof
If you already have the proof, you can no longer be assuming.
Regardless, you f***d up when you claimed in your post that you never assumed,I "infiltrated" a forum, and then told us that you assume I "infiltrated: a forum.
Try to keep your lies straight. You're confusing yourself.
You think engineering a building is constructing a building?
oops, you got confused again.
Says the guy who has responded more times than I can count to being called out on his lack of intellect by shouting a command for someone to eat a male body part. HAHAHAHA
You deemed the place "biologically safe" without even testing the water?!?!
What year were you there to do your "testing"?
It has nothing to do with this case...or their bias...cnn has a track record of flat out lies and deception going back at least to the 1st trip to the sandbox under Sr.
Ohhh, you decided to bring it up completely at random when this particular news piece by CNN was shared.
Good story. Compelling, and rich!
Hmmm, the US Court system seems to disagree. Trump has been indicted for saying it AND for actively taking part in it.
And we GET it. You actually were agreeing that it was utterly ridiculous that people were taking horse dewormer Ivermectin to try and prevent COVID, and anyone who did it or does it is a moron.
You've told us enough times, and we accepted it long ago.
Here, Ill make this statement: I UNDERSTAND SPOKEY WAS NOT TRYING TO SAY IVERMECTIN WAAS APPROVED BY THE FDA FOR COVID PREVENTION, BUT WAS ACTUALLY SHOWING US IT WAS NOT APPROVED BY THE FDA FOR COVID PREVENTION, AND ANYONE WHO THOUGHT OR ACTED OTHERWISE IS A MORON.
Happy?
Yet another...let's be nice and falsehood...
Unless you can show where I said that...
Slo_Ride
Regulator
Slo_Ride
ATLANTA
Buck
BP1Fanatic
BP1Fanatic
