Winners only.
Since old Rob the douche nozzle has us talking about car audio in the dome I will offer up a picture of a different kind of amp. Rob, what are they calling the things you connect the speaker wires to? Hmm? Hell, even the subwoofer Preouts are probably sending a mono signal but are still referenced as plural.
It’s 100% relevant you ignormaus.
Go look at a mono amp chip, and tell me how many outputs it has.
Then, tell me how, using a single speaker, you can bridge the “outputs” on your mono amp to get more power than just using a single output.
Also, answer this: Does connecting a terminal block to my car battery increase the voltage or amperage it can deliver? If I have two positive and two negative rails, does it now deliver 1500 CCA instead of 750?
I’ll wait.
how can we even pay attention to your attempts to debate us when you can't even spell?
Nope. That's why you sound stupid telling someone he's leaving power on the table by not using all terminals on a mono amp.
Why won't you stick to the topic. Why do you jump all around?
How many outputs do you see here?
If it’s a mono amp, I see one output feeding a terminal block with multiple connectors.
Is it a mono amp? What model?
From the guy who complained I wasn’t talking car audio in the thread.
Make up your mind, dopey.
Ahhh, jumping on the Thxone homophobia train.
You must be stuck in an 8th grade mental age too.
Congrats?
Instead of searching for that meme, you should read up on amplifier circuits. Maybe learn something instead of speaking like a fool.
But being educated might result in you being called “woke”. And that’s a bad thing, right?
Too letters transposed while typing. Yeah, their is the dealbreaker. Your just to smart for me, kid.
Tell me more about your extensive study of anatomy where you learned there are no nerves in bone.
For the same reason you talked trash over other peoples spelling or grammar errors. Now that you get called out on it, it's suddenly no big deal. LOL you kill me Gramps.
Congrats?
You are the only one talking about amplifier circuits. Nobody is denying mono amplifiers so your argument is kinda... well, stupid.
Keep trying to spin it. The circuit is what is inside the box, you dope.
The external terminals are connected directly to the internal amplifier circuit, the whole of which is represented by the diagram.
I’ll ask once again: do you think connecting a bus bar to a mono amp circuit creates multiple outputs from that mono amp?
How many outputs does this amplifier offer?
Let us guess... you think none of us know what a mono amplifier is so you feel it is your duty to teach us? There is no need to answer your questions. You didn't answer mine. To the end huh Rob... to the end. You will argue until no one continues to speak to you. No matter the outcome, everyone else is wrong and you are right.
It doesn't matter how many wires you connect to a buss bar if they are outputting a signal, it is an output. It does not matter if the source is a mono signal.
Look at the pic of my amplifier. Both sets of terminals accept wires. I have wired a 2 ohm load to each set of terminals. The amplifier is bridging those terminals INSIDE the amp for a final 1 ohm mono load. What is confusing you? Why are you fighting so hard? You are being a real big baby about losing this argument.
That time you think a typo is a spelling or grammar error.
Tell us more about your personal definition of tautology. You know, the one that no scholar anywhere knows of.
You keep trying to spin it.
Tell us how many outputs a mono amp has if it is connected to two terminal strips, each one with 5 terminals on it.
I’ve asked the question multiple ways, but you always avoid answering it.
Go ahead and answer it: How many outputs does a mono amplifier have when it’s connected to two terminal strips that have 5 terminals each?
And, tell us more about how the mono amplifier is being “bridged” internally. THIS ought to be good.
YOUR words:
Slo_Ride
Regulator
Slo_Ride
ATLANTA
Buck
