Winners only.
Isn’t it weird how you argue so strongly that your feelings are correct, then when they get crushed by fact it all suddenly doesn’t matter to you?
I’d bet good money you look at the numbers and say “I don’t give a fvck, I know I’m right that Biden didn’t reduce them” and then just repeat that feeling any chance you get.
Allegedly.
There are more numbers to the deficit though. Could you list them all?
No, you are reading it right. That spike corresponds with what though? Do you see Biden reducing it? Nope, it is steadily rising, slowly like lava.
Yes, I see Biden reducing it.
Don’t you?
Allegedly.
Do t even try that bullshlt. You’d be like that clerk’s clerk in Florida who says “the country is doing poorly” simply because his COUNTY is doing poorly, when even the rest of his state is doing well.
You gripe about Biden not reducing the deficit. The deficit dropped in 2021 and the 2022 numbers are all lower than 2021.
How do you reconcile your complaint and feeling with the facts that contradict them?
It's below but rising. Is THAT a concept you can't understand? So are you now saying Biden can control inflation?
More red herrings. You’re clutching at straws kid. Pretty sad.
Was the deficit lower in 2021 than 2020?
Is the deficit lower in 2022 than 2021?
Has the deficit been running lower in 2022 than 2019, 2020, and 2021?
View attachment 41824View attachment 41825
You are not very analytical are you? Isn't that your job, to analyze things? There is a reason for the spike at the end of Trumps presidency and it is relevant. Under Biden, right now, though technically lower than the spike, is RISING. You saying that he isn't adding to the deficit or that it doesn't matter because it's not Trump?
That’s not the discussion. You biotched that the deficit is not being reduced under Biden. YOUR words: “Do you see Biden reducing it? Nope,”
Speak to the chart and explain how the smaller numbers under Biden do not exemplify numbers bring “reduced”.
That’s not the discussion. You blotched that the deficit is not being reduced under Biden.
It IS NOT "being" reduced. It is RISING. Fuck Trumps numbers... they are IRRELEVANT. You are comparing to a rise DUE to the COVID pandemic and falsely claiming some kind of victory because the current graph is below the other graph. That doesn't change the FACT that the deficit is rising.
You CANNOT ignore previous deficits if you are going to judge current ones. What the fvck do you think you would be comparing TO?
Now, keep the goalpost where you planted it. Remember YOUR words: “Do you see Biden reducing it? Nope,”
IS THE DEFICIT LOWER UNDER BIDEN THAN IT WAS BEFORE BIDEN?
Comparing it to the past does what? Other than giving the ability to judge it.
I said it is lower than that pandemic induced spike. HOWEVER, it is rising currently.
But that's cool. Ignore the current deficit rise so that you can judge and live in the past. You are a winnier!
You sure about this?
I am looking at monthly federal deficit numbers and it sure looks like comparing the numbers under Biden when he took office are higher than Trumps from the same months the year before.
This chart here seems to show it is getting worse under Biden.
Kid Biden didn't take office until January 2021. Learn how to read your graphs. Math is your enemy. And Geometry isn't your friend either.
Slo_Ride
Regulator
Slo_Ride
ATLANTA
Buck
