Win ISD question
75MonteCarlo
pwned by the R
Hey guys. I just got winisd and I am trying to figure out how to use it. I think I get it pretty well, but i'm having trouble converting specs from Alpine's website to the specs sheet in winisd for entering your own driver parameters.. Winisd has boxes to fill in for stuff like Z and xmax and stuff, but alpine's site doesn't list that. Can you help me translate these specs? If you do, i'll be able to figure it out for next time I enter a sub's specs on my own.
One other thing, how reliable is Winisd for calculating boxes?
here's the specs from Alpine's site regarding their Type-X 12":
# Coil Height (Hvc) : 48.1mm
# Cone Area (Sd) : 529sq. cm
# D.C.Coil Resistance (Re) : 3.6ohm + 3.6ohm
# Electrical Q (Qes) : 0.69
# Equivalent Suspension Stiffness (Vas) : 32liters(1.1cu.ft.)
# Free Air Resonance (Fs) : 28Hz
# Frequency Response : 23Hz - 200Hz
# Gap Height (Hag) : 10mm
# Impedance (Nominal) : 4ohm + 4ohm
# Linear Excursion (X linear) : 19.1mm
# Maximum Excursion (X peak) : 22mm
# Mechanical Excursion (Peak-to-Peak) : 75mm
# Mechanical Q (Qms) : 8.67
# Sensitivity : 83dB/W/M
# Total Loudspeaker Q (Qts) : 0.64
Thank you!
the data you have should be enough, and as far as the Xmax I would use the X linear. Use the help guide it explains alot on how to enter data.
As far as being accurate, I think it only gives general results
75MonteCarlo
pwned by the R
75MonteCarlo
Saskatchewan, Canada
xxx.x dB
