Will this work?
gnatnoop
ca
im planning on running one or more batterys to help with voltage drops, but the problem is i cant run them in the cab of my truck.. due to limited space, with it being a single cab (another batt in the engine compartment is not a option). However i do have a nice little tool box right behind the cab.. so i was thinking is it possible to run some thick power wire from my front batt to my rear batt(s) and still have my amp connected to the front batt... look at picture below if that didnt make any sense
k i now have a question about this, will i be able to run the system off the rear batts with out hooking it up back there while the car is off, or will i have to hook the amps to the back batts.. what amp isolator should i run, i have a 220 amp alt. will i have a voltage drop because of the isolator when the truck is running?
anwser this question...please
you should hook ut to the rear batt any way and up grade you charging wire from your alt to batt fuse b-tween frnt batt and rear batts and b-tween amps and rear batts
will mean reworking some of your power but is worth it and then yes if you isolate the batts w/ a switch you can run your system w/o truck on but not for long (batts will run dead) i do have a power inverter for show cars i could sell you (demo all day w/o running batts down)
some thing like these i have a few so i'll let them go for 150 shipped ea
you can run your whole system on this as long as you have a wall to plug into
don't call # in post pm me here i'll fix you up
The isolators will give a voltage drop of 0.4 to 0.7 volts because of how they are made. I'm not sure what will happen if you run more power than recommended, it will probably fry the isolator.
What amps, how much power are you running. What size batts are you planning on getting? If you can't get 3 of the same size batts, then just get 2 big batts in the back and remove the batt from the front. Thats what I'm doing with 2.5kwrms and 2 group 31 batts.
im running about 1500 watts rms, soon to be about 3000 im going to get 2 of the big c&d's. i have to have a battery upfront as i already have a bunch of stuff wired to that one..
gnatnoop
gnatnoop
ca
gnatnoop
michigan born
    May 14, 2026
michigan born
    May 14, 2026
