will this amp work
  • 2
That legacy will probably give you around 200x2 rms bridged. So yes, it will work, but you obviously won't be getting peak performance from your subs. I'm not very familiar w/perf. tech. I'm thinking they're low to mid level stuff and would probably be fine with 400-500 rms. You're going to need a pretty serious amp to get a a lot out of them.
188
388
486
  • Locked
773
Amp
562
sk8board4life86
sk8board4life86
gautier
n2audio
