will this amp work wit my 12 if not chose one that will thanks
It will work for one of them. For 2 dual-4 ohm subs, you need an amp that puts out the power you need (700w rms) at 1 or 4 ohms. If you want to power both of them, something like THIS might work for a cheaper solution. There are definitely better amps out there, but it all depends on how much you're looking to spend. What subs are you using and what's your budget.
The bigger Powerbass (the last link) is the only one that would power your subs decently. I can't say anything about the quality of their amps, but none of the other amps you linked would power both of your subs. Like I said before, you need an amp that puts out 700w RMS at either 1 or 4 ohms. Might try something like:
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16338
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13470
Personally, I'd get the Orion. The 1200Ds were very popualar around here about a year ago. From what I understand, the pre-buyout amps were pretty nice.
jerseyflipper
jerseyflipper
Donaldsonville,LA
Hintzyboy
