Will these measurements work
NonEvo
tx
I am going to build a sealed box for a single RF stage 3 10" sub. RF says that the optimum sealed volume is like .625 cubic feet. If I use 3/4" mdf will a box with the outer measurements of 12x12x12 work. I believe that is just a little bit more than .625 but it should be close. If it makes a difference the sub will be pushed by a kicker kx400.1 at 2 ohms.
I can make the box deeper or taller, but I need the width to stay the same because I am trying to mount the amps on one side of the box. Since I only have 33" from wheel well to wheel well I need the keep the box as narrow as possible.
NonEvo
NonEvo
tx
NonEvo
michigan born
    May 14, 2026
michigan born
    May 14, 2026
