WarDrumz
Hebrew Israelite
I keep reading that Sd times Xmax gives you the amount of air a sub can displace. And since BASS is, from what I understand, all about moving air, then will the numbers ALWAYS tell you the loudest sub(s) before you even have to hear them?
Because if that's the case then all the "SQL" fans just need to find a sub that sounds good with the longest throw possible.
And again, if that is true than these (below) are in a class by themselves.
The Untouchables:
1) JL Audio 13W7
2) Elemental Designs A Series 15"
3) Resonant Engineering XXX 15"
Is that ALWAYS the case?
The Untouchables:
1) JL Audio 13W7
