Will running amp with 8 ohm load rob power?
ccajun4real
I have an eclipse 87121 DVC 4 ohm sub and the amp I have (JBL 180.2) to power it is only capable of 360 x 1 @4 ohms. It can not be used at 2 ohms in bridged mode.
So it looks as if I will have to run it at 8 ohms since there is no way to bridge a DVC 4 ohm sub at 4 ohms.
Will running it at 8 ohms decrease the power output from the amp?
Will it work well and provide enough power?
Thanks for the help.
Cajun
You could wire it at 2 ohms and put it on one of the channels, or you could wire it at 8 ohms and bridge the amp.
FYI usually when you go from 4 ohms to 8 it will just cut the power output in half. It will not hurt the amp in any way.
you can still run it at 8 ohms, just won't get the same power as at 4 ohms
Unfortunately that would give me only 180 RMS which is not acceptable. Anyone want to trade a JBL P 180.2 for an amp that would do the job? I also have a P 150.1 but that only gives me 150 x 1 @ 2ohms
Cajun
Well if I run at 8 ohms will at least make the amp work alot less? I mean will it not heat as much and be easier on the amp?
Do you think it is enough for the sub that is 300 RMS max? Thanks to all
Cajun
Well if I run at 8 ohms will at least make the amp work alot less? I mean will it not heat as much and be easier on the amp? Cajun
8 ohms means your amp is only putting out 1/2 it's output vs a 4 ohm load. So yes, its working less and will not heat up as much.
RMS and MAX are totally different. Which do you mean?
ccajun4real
ccajun4real
Watertown, NY
ccajun4real
