Will it work
dctasson
So I have a leased car. I want it to go BOOOOOOM BOOOM! So this is what im thinking........buy a headphone splitter for my ipod have one cable go into the aux in on my dash and have the other go in to the amp's aux in. Would it work?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I would but ihave no idea what your talking about lol.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I would tend to say not very well, most HU's have at least a 2 volt output. An ipod is much much lower, they only put out about 30mW (on a 32 ohm load like most headphones that is less than a volt).
You could probably get a line out converter, then you wouldn't have to change your HU.
Shit my comp is slow.
Here is what we mean by a LOC,
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=721&i=142SLC4&tp=2001
Chopped from Crutchfield
So you're trying to connect an amplifier without speaker-level inputs to a car stereo that doesn't have preamp outputs? It can be done, but you'll need a line output converter to make it happen. The SLC4 from Scosche can handle up to four speaker-level inputs and four RCA outputs — enough for a 4-channel amp or a multi-amp setup.
Connect the speaker leads from your car stereo to the SLC4. It reduces the incoming speaker-level signals so that outgoing signals are compatible with the preamp inputs on your amplifier. You will then need to use two RCA patch cords (not included) to make the connections to your amp.
The SLC4 features adjustable gain settings on each channel, and it's compatible with any car stereo. Warranty: 90 days.
Or you could find an amp that has speaker level inputs.
dctasson
dctasson
Detroit
dctasson
Mike Mccabe
