Will I hit 149.3? hmmmm
Hes a big guy.//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
and he could kill you in under 5 seconds //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif might wanna behave
Yeah, his G35 flexes! I was very surprised his setup hit the same number as my BTL, but there are some factors differentiating our systems. His trunk opens up into the cabin through the little seat opening, and he has two 15's... which will almost always get louder than a single 18. All in all, our team took three trophies home, so it was a nice little show.
Going to set my goal for 147 for the show in October... the 29th I believe.
wuts the point of being a complete dick on the forum when u have absolutely no balls in real life? You wouldnt walk up to someone, stare them in there face and say something so disrespectful to them when they have done nothing to you.
D-bag.
Bought my P880PRS and spent $120 at Knu today for wiring, fuse holder, etc. This weekend is going to add some dbeeeezzzz!
Not to be a dick or anything, but it's not as easy as you think to get louder. You're setting your expectations too high. . . shouldn't do that because you'll get let down easily when you see your score. Changing the head unit and adding wire will gain you very little, in the tenths if that.
box is being redone for SPL too //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif read back. AMP and Sub are the only things staying the same. His current box is too big and tuned for daily driving.
I don't think you're a dick, don't worry. I know it's not easy, and I'm learning more and more as I go along... but I'm happy with my score at this show, 145.8. We're rebuilding the box soon, tuned much higher (currently at 30 hz), installing my alternator and doing the big 3 this weekend too. We went to set the gains and my amp isn't giving out the voltage we're looking for. We know it has something to do with the way the equalizer is working... we can finally let the amp loose on my sub once the equalizer is removed and we use the built in EQ with the 880; should fix the voltage problem we're getting.
I still think you need to get on the TL so you know the numbers are consistant.
Yeah, some guy here on the forums is selling his for $475 or so, but won't answer our PMs... the team is looking to purchase one and host local shows eventually. The guy that holds these local shows with his AC mic makes thousands of dollars per show easily!
do you know the name of the guy that holds the local shows you go to?
Kenny Pollock
drag it!
Kenny Pollock
Hollywood, Florida Low: Yes
rollin_cc_s10
michigan born
    May 14, 2026
michigan born
    May 14, 2026
