Will 1 kicker KXA24001 amp be enough for 3 type R 12" ?
  • 2
Three D4 ohm subwoofers won't wire to 1 ohm. Hope you didn't already buy that amp because $900 for a 2400 watt amp is insane as well as not ideal for your subwoofer setup.
Taramps Smart 3 or MD3k 2 ohm version is what I would recommend.
465
955
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
LMJexploder
CarAudio.com Recruit
LMJexploder
Seattle WA
SlugButter
    May 4, 2024
slater
    May 2, 2024
