why not?
i have thought about that too i tried goofin off with a lil 6.5 the other day but idk how to make the coil a certain ohm and i dont have small spiders and such. but for a sub like that only have to worry about the soft parts ripping or such.
The pole, also known as the T-yoke, creates the return path for the magnetic flux. Without it, you'd have an awfully inefficient permanent magnetic field for the coil's electro-magnetic field to work with.
The vent through the pole is simply a means to offer a certain degree of cooling, but it can also relieve the compression built-up inside the motor structure under heavy excursion. This can also affect the Q of the driver, both mechanically and electrically.
kwitcherbichin
kwitcherbichin
stantonsburg, nc
ciaonzo
BP1Fanatic
BP1Fanatic
