why not?
timvanderet
Ca
I am in the process of planing and purchasing equipment for my new system. When my amp comes in (Elevation DX 1500.1 does around 2k at 1 ohm) I was planing on buying a new battery for under the hood (most likely a yellow top). It then occured to me I could keep the stock battery under the hood and put the yellow top in the back for about the same price. I would already be buying 1/0 wire for my amp, so I could just run that from battery to battery instead. Are there any disadvantages to this? The way I look at it I'm getting all the benifiets of running a battery in the back with no real negatives (other than spending a little more money on cable).
Thoughts?
Thoughts?
nG
Thoughts?
lol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerkslol you guys are jerks
nG
tafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkaloltafkalol
nG
nG
timvanderet
timvanderet
Ca
timvanderet
michigan born
    May 14, 2026
michigan born
    May 14, 2026
