Why not welding cable?
I was pleasently suprised by the flex in the coppercableman wire, extremley flexible which I like. More flexible than alot of the audio companies and I like that it has a thick outside jacket and pvc inner, not a big deal in my case my probably useful for someone running it under the car
when i got my hyperflex kit i was kinda shocked, the 4ga monster wire i was replacing was obviously bigger than the 4ga hyperflex that was included,
The main difference between welding cable and audio power cable is the diameter of the strand size. The strands are smaller in size in audio cable which means you have more wire in the gauge because there is less space between the strands.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
im learning, and always wonder how they came up with the sizes anyhow.
thats cool information
Here's one for you. If you double up a run of a certain gauge, you drop 3 numbers in gauge (i.e. 2 runs of 4 ga is the same as 1 run of 1 ga). If you know the gauge of the individual strands, you can figure out how many strands you need to get the desired final gauge.
Your notation is incorrect. The normal notation for 0ga is 1/0. Going bigger than that is 00, 000, 0000, etc, which are noted with the number of "0s" as the first number followed by the "/" and a "0."
2 runs of 1/0 (0ga) would be the same as 4/0 (0000ga).
i knew it didnt look right....lol
thanks
kush-divinity
Klan of TN support Obama
kush-divinity
in line for DNA testing
IDSkoT
