Why not 24 volt??
bumpasauras
Always Hurtin Ears!!
Ok so I am an oilfield mechanic and in my line of work I come into contact with 24 volt alts off of large industrial engines all the time. So I got to thinking, with the availability of 24 volt alts and the ease of wiring 2 12 volt bats to 24 volt why have amp manufactures not done 24 volt amps?? It just seems logical to add a 2nd alt isolated system @ 24 volts. Some of these alts are 600 amps . My second thought was that since there are no amps (that I know of) that will take 24v why not build a really tough external regulator that you could run at 18v or 16v is this possible??
Surley some one has thought of this. I have a pile of them at work and have been trying to come up with a use for them.. Any help on this would be awsome it's just a shame to send these 500 and 600 amp alts to the scrap yard.
Helll ill give a few of them to anybody that can solve this problem.
I have a few 48 volt Deka forklift batteries, they only weigh about 2800 pounds each //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The cool thing about running at 24V is you don't need as much amperage (wattage = voltage x amperage)... 600A at 24V would be a helluva reserve! Equiv to about 1000A on a typical "12V" setup. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
^^^^exactly what I was thinking only problem is the amp selection is sparse at best. I am currently working with a friend of mine who is an electrical engineer to make a stand alone voltage regulator that will have a potentiometer so you can actually dial in your voltage.
The plan is to regulate the voltage down to 18v which of course opens up amp selection tremendously.
I am not a electrical engineer but this thing will have to be fool proof before I trust any of my equipment to is lol.
That is a good idea also. There's a lot more amps that will run at 16 or 18V.. It would be a relatively easy circuit to build, but you will need some serious transistors or rheostats depending on how the circuit is designed.
bumpasauras
bumpasauras
West. TEXAS
shizzzon
maylar
    Jun 2, 2024
    Jun 1, 2024
