Why does this song clip my amp?
SmokeEater850
So far, it only happens on one song, Young Jeezy - Hypontize. It only happens on the second bass drop... The low one. I figured maybe the LPF on my amp was up too high so I dropped it down, still does it. The gain is just a hair over 3/4 of the way up and it looks like the LPF appears to be set right around 40 or so, give or take. The subs are Kicker CVR and the amp is a Directed D2400. They are in a pre fab sealed enclosure with seperate chambers.
Thanks.
Well, it plays pretty loud but I wouldn't say louder than the others, if a clean copy still clips the amp should I go lower on the LPF? Maybe higher? I'm not even real sure what they do. I have read about them but don't really understand what it is I'm reading lol.
How do you know that it is actually clipping?
when you say it "clipped", is it actually going into the protect mode?
What is atually happening when the problem occurs?
Does the amp have Bass EQ and possibly turned up too high?
Different songs have different levels on their mastering, this especially comes into play if you have your gains on your amp set to barely before clipping. Just turn down your bass or volume on that song a few notches and it should be fine, unless its recorded way above normal levels. Either way, get a clean version of it.
thus far, from the thread, the "clipping" claim needs to be explained. Given the general difficulty for an objective measurement of clipping, and the general acceptance of mild clipping, it seems likely the term is being applied wrong.
the following are problems and solutions:
1.) the amplifier is occasionally entering protect mode. a reduction in gains, or correction of wiring errors can fix this, with the latter being preferred.
2.) an inprecise tool, such as a DMM, is being misapplied to infer the form of distortion caused when the amplifier cannot force the speaker any further inward or outward due to its design limitations. this limitation is called "clipping".
3.) audible distortion is present. this may be an issue with any element in the audio system including the human and the speaker and the amp and the HU, and ect... A speaker bottoming out will certainly sound unplesant regardless of how clean the amplifier is.
4.) a precision instrument is used to determine clipping. Because the amplifier is set using a sine wave, and music is comprised of many sounds, some of which are delayed and reduced by filters, it may be possible that the summation of these filtered sounds will exceed the peak capabilities of the amplifier (even though the average power may be reduced).
in general, #2 may be a non issue. #3 may mean you need a highpass/subsonic filter to prevent overexcursion. #4 is generally not solvable except by purchasing a larger amplifier, but it is also not terribly important either.
My guess is like some one else stated, you probably got your gains turned up to much.
songs don't clip....people do FYI
Guess you haven't heard Madonna's new album then! lol
Man, that whole album clips worse than any other recordings I've heard. I know studio clipping is the "in" thing but it's getting rediculous!
SmokeEater850
SmokeEater850
Pensacola, FL
SmokeEater850
