I just called Alpine technical support and asked them what the impedence was on the pre outs for the CDA-9887. He said 10K ohms, which is exactly the same as it was on my old HU, the CDA-7892. This was the only complaint I had with this HU as the high impedence basically means instead the of having a true 4 volt pre out, the end effect is about the same as having a 1 volt pre out. Why does Alpine insist on having such a high impedence? Most other company's HU's have an impedence of only 100 ohms or less. When using the the Alpine's with the high impedence pre outs in my system, this means I have to have my amp's gain for the sub, and the HU's sub out level adjustment turned all the way up just to get a moderate level of output. So now if I decide I want to go with a 9887, I'm going to also have to purchase a line driver if I want to get the full output capabilities from my system. Why can't Alpine make their HU's with a normal amount of impedence like everyone else? //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
